Managing qube kernels
Warning
By default, VMs kernels are provided by dom0. (See here for information about upgrading kernels in dom0.) This means that:
  1. You can select the kernel version (using GUI VM Settings tool or qvm-prefs commandline tool);
  2. You can modify kernel options (using qvm-prefs commandline tool);
  3. You can not modify any of the above from inside a VM;
  4. Installing additional kernel modules is cumbersome.
Note: In the examples below, although the specific version numbers might be old, the commands have been verified on R3.2 and R4.0 with debian-9 and fedora-26 templates.
To select which kernel a given VM will use, you can either use Qubes Manager (VM settings, advanced tab), or the qvm-prefs tool:
[user@dom0 ~]$ dnf list --installed kernel
Installed Packages
kernel.x86_64            1000:6.12.47-1.qubes.fc37             @qubes-dom0-cached
kernel.x86_64            1000:6.12.54-1.qubes.fc37             @qubes-dom0-cached
kernel.x86_64            1000:6.12.59-1.qubes.fc37             @qubes-dom0-cached
[user@dom0 ~]$ qvm-prefs my-appvm kernel
6.12.59-1.fc37
[user@dom0 ~]$ qvm-prefs my-appvm kernel 6.12.54-1.fc37
[user@dom0 ~]$ qvm-prefs -D my-appvm kernel
To check/change the default kernel you can either go to “Global settings” in Qubes Manager, or use the qubes-prefs tool:
[user@dom0 ~]$ qubes-prefs default-kernel
6.12.59-1.fc37
[user@dom0 ~]$ qubes-prefs default-kernel 6.12.54-1.fc37
To view kernel options, you can use the GUI VM Settings tool; to view and change them, use qvm-prefs commandline tool:
[user@dom0 ~]$ qvm-prefs my-appvm kernelopts
swiotlb=2048
[user@dom0 ~]$ qvm-prefs my-appvm kernelopts "swiotlb=10240 apparmor=1 security=apparmor"
Installing different kernel using Qubes kernel package
VM kernels are packaged by the Qubes team in the kernel packages. Generally, the system will keep the three newest available versions. You can list them using rpm or dnf commands:
[user@dom0 ~]$ rpm -qa 'kernel'
kernel-6.12.47-1.qubes.fc37.x86_64
kernel-6.12.54-1.qubes.fc37.x86_64
kernel-6.12.59-1.qubes.fc37.x86_64
Installed Packages
If you want a more recent version, you can check qubes-dom0-unstable and qubes-dom0-current-testing repositories. There is also kernel-latest package which should provide a more recent (non-LTS) kernel, but has received much less testing. As the names suggest, keep in mind that those packages may be less stable than the default ones.
To check available versions in the qubes-dom0-current-testing repository:
[root@dom0 ~]# qubes-dom0-update --enablerepo=qubes-dom0-current-testing --action=list kernel-latest kernel
Using sys-whonix as UpdateVM for Dom0
Updating package lists. This may take a while...
Fedora 37 - x86_64                              3.1 kB/s | 5.1 kB     00:01
Fedora 37 - x86_64 - Updates                    3.2 kB/s | 5.0 kB     00:01
Qubes Host Repository (updates)                 2.4 kB/s | 2.7 kB     00:01
Qubes Host Repository (updates-testing)         3.1 kB/s | 2.8 kB     00:00
Installed Packages
kernel.x86_64           1000:6.12.47-1.qubes.fc37     @System
kernel.x86_64           1000:6.12.54-1.qubes.fc37     @System
kernel.x86_64           1000:6.12.59-1.qubes.fc37     @System
Available Packages
kernel.src              1000:6.12.63-1.qubes.fc37     qubes-dom0-current-testing
kernel.x86_64           1000:6.12.63-1.qubes.fc37     qubes-dom0-current-testing
kernel-latest.src       1000:6.18.2-1.qubes.fc37      qubes-dom0-current-testing
kernel-latest.x86_64    1000:6.18.2-1.qubes.fc37      qubes-dom0-current-testing
No packages downloaded
Installing a new version from qubes-dom0-current-testing repository:
[root@dom0 ~]# qubes-dom0-update --enablerepo=qubes-dom0-current-testing kernel
Downloading packages. This may take a while...
Fedora 37 - x86_64                              1.8 kB/s | 5.1 kB     00:02
Fedora 37 - x86_64 - Updates                    3.5 kB/s | 5.0 kB     00:01
Qubes Host Repository (updates)                 2.1 kB/s | 2.7 kB     00:01
Qubes Host Repository (updates-testing)         2.2 kB/s | 2.8 kB     00:01
Last metadata expiration check: 0:00:01 ago on Fri Dec 26 21:49:54 2025.
Package kernel-1000:6.12.47-1.qubes.fc37.x86_64 is already installed.
Package kernel-1000:6.12.54-1.qubes.fc37.x86_64 is already installed.
Package kernel-1000:6.12.59-1.qubes.fc37.x86_64 is already installed.
Dependencies resolved.
 Package      Arch   Version                   Repository                  Size
Installing:
 kernel       x86_64 1000:6.12.63-1.qubes.fc37 qubes-dom0-current-testing  13 M
 kernel-modules
              x86_64 1000:6.12.63-1.qubes.fc37 qubes-dom0-current-testing  84 M
Removing:
 kernel       x86_64 1000:6.12.47-1.qubes.fc37 @System                     42 M
 kernel-modules
              x86_64 1000:6.12.47-1.qubes.fc37 @System                    508 M
Transaction Summary
Install  2 Packages
Remove   2 Packages
Total download size: 97 M
DNF will only download packages for the transaction.
Downloading Packages:
Complete!
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Qubes OS Repository for Dom0                      2.9 MB/s | 3.0 kB     00:00
Qubes OS Repository for Dom0                      2.2 MB/s |  66 kB     00:00
Nothing to do.
Complete!
[root@dom0 ~]# dnf list kernel
Installed Packages
Available Packages
kernel.x86_64             1000:6.12.63-1.qubes.fc37             qubes-dom0-cached
[root@dom0 ~]# dnf install kernel-1000:6.12.63-1.qubes.fc37
Installing:
 kernel           x86_64   1000:6.12.63-1.qubes.fc37   qubes-dom0-cached     13 M
 kernel-modules   x86_64   1000:6.12.63-1.qubes.fc37   qubes-dom0-cached     84 M
Removing:
 kernel           x86_64   1000:6.12.47-1.qubes.fc37   @qubes-dom0-cached    42 M
 kernel-modules   x86_64   1000:6.12.47-1.qubes.fc37   @qubes-dom0-cached   508 M
Transaction Summary
Install  2 Packages
Remove   2 Packages
Total size: 97 M
Is this ok [y/N]: y
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Installed:
  kernel-1000:6.12.63-1.qubes.fc37.x86_64
  kernel-modules-1000:6.12.63-1.qubes.fc37.x86_64
Removed:
  kernel-modules-1000:6.12.47-1.qubes.fc37.x86_64
Complete!
The newly installed package is set as the default VM kernel.
Installing different VM kernel based on dom0 kernel
It is possible to package a kernel installed in dom0 as a VM kernel. This makes it possible to use a VM kernel which is not packaged by the Qubes team. This includes:
  • using a Fedora kernel package
  • using a manually compiled kernel
To prepare such a VM kernel, you need to install the qubes-kernel-vm-support package in dom0 and also have matching kernel headers installed (kernel-devel package in the case of a Fedora kernel package). You can install requirements using qubes-dom0-update:
[user@dom0 ~]$ sudo qubes-dom0-update qubes-kernel-vm-support kernel-devel
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
Running command on VM: 'sys-firewall'...
Loaded plugins: langpacks, post-transaction-actions, yum-qubes-hooks
Package 1000:kernel-devel-4.1.9-6.pvops.qubes.x86_64 already installed and latest version
Resolving Dependencies
Installing:
 qubes-kernel-vm-support      x86_64      3.1.2-1.fc20   qubes-dom0-cached 9.2 k
Transaction Summary
Install  1 Package
Total download size: 9.2 k
Installed size: 13 k
Is this ok [y/d/N]: y
Downloading packages:
Running transaction (shutdown inhibited)
  Installing : qubes-kernel-vm-support-3.1.2-1.fc20.x86_64                  1/1
Creating symlink /var/lib/dkms/u2mfn/3.1.2/source ->
                 /usr/src/u2mfn-3.1.2
DKMS: add completed.
  Verifying  : qubes-kernel-vm-support-3.1.2-1.fc20.x86_64                  1/1
Installed:
  qubes-kernel-vm-support.x86_64 0:3.1.2-1.fc20
Complete!
Then you can call the qubes-prepare-vm-kernel tool to actually package the kernel. The first parameter is kernel version (exactly as seen by the kernel), the second one (optional) is short name. This is visible in Qubes Manager and the qvm-prefs tool.
[user@dom0 ~]$ sudo qubes-prepare-vm-kernel 4.1.9-6.pvops.qubes.x86_64 4.1.qubes
--> Building files for 4.1.9-6.pvops.qubes.x86_64 in /var/lib/qubes/vm-kernels/4.1.qubes
---> Recompiling kernel module (u2mfn)
---> Generating modules.img
mke2fs 1.42.12 (29-Aug-2014)
---> Generating initramfs
--> Done.
Kernel files structure
Kernel for a VM is stored in /var/lib/qubes/vm-kernels/KERNEL_VERSION directory (KERNEL_VERSION replaced with actual version). Qubes 4.x supports the following files there:
  • vmlinuz - kernel binary (may not be a Linux kernel)
  • initramfs - initramfs for the kernel to load
  • modules.img - ext4 filesystem image containing Linux kernel modules (to be mounted at /lib/modules); additionally it should contain a copy of vmlinuz and initramfs in its root directory (for loading by qemu inside stubdomain)
  • default-kernelopts-common.txt - default kernel options, in addition to those specified with kernelopts qube property (can be disabled with no-default-kernelopts feature)
All the files besides vmlinuz are optional in Qubes R4.2 or newer.
Using kernel installed in the VM
Non-minimal debian and fedora templates already have grub and related tools preinstalled so if you want to use one of the distribution kernels, all you need to do is clone either template to a new one, then:
[user@dom0 ~]$ qvm-prefs <clonetemplatename> virt_mode hvm
[user@dom0 ~]$ qvm-prefs <clonetemplatename> kernel ''
Depending on vm and kernel you’re running, you may also want to disable memory balancing and change the amount of memory vm has:
[user@dom0 ~]$ qvm-prefs <clonedtemplatename> maxmem 0
[user@dom0 ~]$ qvm-prefs <clonedtemplatename> memory 2000
Installing kernel in Fedora VM
Fedora distribution kernel
Install kernel and the packages required to run vm with its own kernel:
[root@fedora-vm ~]# dnf install kernel qubes-kernel-vm-support grub2
Once the kernel is installed, you need to setup grub2 by running:
[root@fedora-vm ~]# grub2-install /dev/xvda
Finally, you need to create a GRUB configuration. You may want to adjust some settings in /etc/default/grub; for example, lower GRUB_TIMEOUT to speed up VM startup. Then, you need to generate the actual configuration. In Fedora it can be done using the grub2-mkconfig tool:
[root@fedora-vm ~]# grub2-mkconfig -o /boot/grub2/grub.cfg
Fedora custom kernel
If you are using a manually built kernel, you need to handle the initramfs and kernel modules on your own. Take a look at the dkms documentation, especially the dkms autoinstall command may be useful. If you did not see the kernel install rebuild your initramfs, or are using a manually built kernel, you will need to rebuild it yourself. Replace the version numbers in the example below with the ones appropriate to the kernel you are installing:
[root@fedora-vm ~]# dracut -f /boot/initramfs-4.15.14-200.fc26.x86_64.img 4.15.14-200.fc26.x86_64
You can safely ignore this error message:
grub2-probe: error: cannot find a GRUB drive for /dev/mapper/dmroot. Check your device.map
Then shutdown the VM.
Notes:
  • You may also use PV mode instead of HVM but this is not recommended for security purposes.
  • If you require PV mode, install grub2-xen-pvh in dom0 and change the template’s kernel to pvgrub2-pvh.
  • If you require PVH mode, install grub2-xen-pvh in dom0 and change the kernel to pvgrub2-pvh.
  • To install grub2-xen-pvh run the command sudo qubes-dom0-update pvgrub2-pvh in dom0.
Installing kernel in Debian VM
Debian distribution kernel
Apply the following instruction in a Debian template or in a Debian standalone.
Using a distribution kernel package the initramfs and kernel modules should be handled automatically.
Install distribution kernel image, kernel headers and the grub.
[root@debian-vm ~]# apt install linux-image-amd64 linux-headers-amd64 grub2 qubes-kernel-vm-support
If you are doing that on a qube based on “Debian Minimal” template, a grub gui will popup during the installation, asking you where you want to install the grub loader. You must select /dev/xvda (check the box using the space bar, and validate your choice with “Enter”.) If this popup does not appear during the installation, you must manually setup grub2 by running:
[root@debian-vm ~]# grub-install /dev/xvda
You can safely ignore this error message: grub2-probe: error: cannot find a GRUB drive for /dev/mapper/dmroot. Check your device.map
You may want to adjust some settings in /etc/default/grub (or better /etc/default/grub.d). For example, lower GRUB_TIMEOUT to speed up VM startup. You need to re-run sudo update-grub after making grub configuration changes.
Go to dom0: Qubes VM Manager ‣ right click on the VM ‣ Qube settings ‣ Advanced
Depends on Virtualization mode setting:
  • Virtualization mode PV: Possible, however use of Virtualization mode PV is discouraged for security purposes.
    • If you require Virtualization mode PV, install grub2-xen-pvh in dom0. This can be done by running command sudo qubes-dom0-update pvgrub2-pvh in dom0.
  • Virtualization mode PVH: Possible. Install grub2-xen-pvh in dom0.
  • Virtualization mode HVM: Possible.
The Kernel setting of the Virtualization mode setting:
  • If Virtualization is set to PVH -> Kernel -> choose pvgrub2-pvh -> OK
  • If Virtualization is set to PV -> Kernel -> choose pvgrub2 -> OK
  • If Virtualization is set to HVM -> Kernel -> choose none -> OK
Start the VM.
The process of using Qubes VM kernel with distribution kernel is complete.
Debian custom kernel
Any kernel can be installed. Just make sure to install kernel headers as well.
If you are building the kernel manually, do this using dkms and initramfs-tools.
Run DKMS. Replace this with actual kernel version.
[root@debian-vm ~]# dkms autoinstall -k <kernel-version>
For example.
[root@debian-vm ~]# dkms autoinstall -k 4.19.0-6-amd64
Update initramfs.
[root@debian-vm ~]# update-initramfs -u
The output should look like this:
[root@debian-vm ~]# dkms autoinstall -k 3.16.0-4-amd64
    u2mfn:
    Running module version sanity check.
      - Original module
        - No original module exists within this kernel
      - Installation
        - Installing to /lib/modules/3.16.0-4-amd64/updates/dkms/
    depmod....
      DKMS: install completed.
    $ sudo update-initramfs -u
    update-initramfs: Generating /boot/initrd.img-3.16.0-4-amd64
Troubleshooting
In case of problems, visit the VM Troubleshooting guide to learn how to access the VM console, view logs and fix a VM kernel installation.
