Secondary storage
Warning
Storing qubes on Secondary Drives
Suppose you have a fast but small primary SSD and a large but slow secondary HDD. You may want to store a subset of your qubes on the HDD. Or if you install a second SSD, you may want to use that for storage of some qubes. This page explains how to use that second drive.
Instructions
Qubes 4.0 is more flexible than earlier versions about placing different VMs on different disks. For example, you can keep templates on one disk and app qubes on another, without messy symlinks.
You can query qvm-pool to list available storage drivers:
$ qvm-pool --help-drivers
qvm-pool driver explanation:
<file> refers to using a simple file for image storage and lacks a few features.
<file-reflink> refers to storing images on a filesystem supporting copy on write.
<linux-kernel> refers to a directory holding kernel images.
<lvm_thin> refers to LVM managed pools.
In theory, you can still use file-based disk images (“file” pool driver), but they will lack some features: for example, you won’t be able to do backups without shutting down the qube.
Additional storage can also be added on a Btrfs filesystem. A unique feature of Btrfs is that data can be compressed transparently. The subvolume can also be backed up using snapshots for an additional layer of protection; Btrfs supports differents level of redundancy; it has parity checksum; Btrfs volumes can be expanded or shrunk. Starting or stopping a VM has less impact and less chance of causing slowdown of the system as some users have noted with LVM. Relevant information for general Btrfs configuration will be provided after the section on LVM storage.
LVM storage
These steps assume you have already created a separate volume group and thin pool (not thin volume) for your second drive.. See also this example if you would like to create an encrypted LVM pool (but note you can use a single logical volume if preferred, and to use the -T option on lvcreate to specify it is thin). You can find the commands for this example applied to Qubes at the bottom of this R4.0 section.
First, collect some information in a dom0 terminal:
$ sudo pvs
$ sudo lvs
Take note of the VG and thin pool names for your second drive, then register it with Qubes, where <pool_name> is a freely chosen pool name, <vg_name> is LVM volume group name and <thin_pool_name> is LVM thin pool name:
$ qvm-pool add <pool_name> lvm_thin -o volume_group=<vg_name> -o thin_pool=<thin_pool_name> -o revisions_to_keep=2
Btrfs storage
Theses steps assume you have already created a separate Btrfs filesystem for your second drive, that it is encrypted with LUKS and it is mounted. It is recommended to use a subvolume as it enables snapshotting the VM data independently of any other files that you may want to store on the filesystem.
It is possible to use an existing Btrfs storage if it is configured. In dom0, available Btrfs storage can be displayed using:
$ mount -t btrfs
$ sudo btrfs filesystem show
To register the storage to qubes use the following command where <pool_name> is a freely chosen pool name adn <dir_path> is the mounted path to the second Btrfs storage:
$ qvm-pool add <pool_name> file-reflink -o dir_path=<dir_path> -o revisions_to_keep=2
Using the new pool
Now, you can create qubes in that pool:
$ qvm-create -P <pool_name> --label red <vmname>
It isn’t possible to directly migrate an existing qube to the new pool, but you can clone it there, then remove the old one:
$ qvm-clone -P <pool_name> <sourceVMname> <cloneVMname>
$ qvm-remove <sourceVMname>
If that was a template, or other qube referenced elsewhere (netVM or such), you will need to adjust those references manually after moving. For example:
$ qvm-prefs <appvmname_based_on_old_template> template <new_template_name>
Example setup of second drive.
Assuming the secondary hard disk is at /dev/sdb , you can encrypt the drive as follows. Note that the drive contents will be completely erased, In a dom0 terminal run this command - use the same passphrase as the main Qubes disk to avoid a second password prompt at boot:
$ sudo cryptsetup luksFormat --sector-size=512 /dev/sdb
$ sudo blkid /dev/sdb
(The --sector-size=512 argument can sometimes work around an incompatibility of storage hardware with LVM thin pools on Qubes. If this does not apply to your hardware, the argument will make no difference.)
Note the device’s UUID (in this example “b209…”), we will use it as its luks name for auto-mounting at boot, by editing /etc/crypttab, and adding this line to crypttab (replacing both “b209…” entries with your device’s UUID taken from blkid) :
luks-b20975aa-8318-433d-8508-6c23982c6cde UUID=b20975aa-8318-433d-8508-6c23982c6cde none
Reboot the computer so the new luks device appears at /dev/mapper/luks-b209… You can then create the new pool by running this command in a dom0 terminal (substitute the b209… UUIDs with your UID):
For LVM
First create the physical volume:
$ sudo pvcreate /dev/mapper/luks-b20975aa-8318-433d-8508-6c23982c6cde
Then create the LVM volume group, we will use for example “qubes” as the :
$ sudo vgcreate qubes /dev/mapper/luks-b20975aa-8318-433d-8508-6c23982c6cde
And then use “poolhd0” as the (LVM thin pool name):
$ sudo lvcreate -T -n poolhd0 -l +100%FREE qubes
Finally we will tell Qubes to add a new pool on the just created thin pool:
$ qvm-pool add poolhd0_qubes lvm_thin -o volume_group=qubes -o thin_pool=poolhd0 -o revisions_to_keep=2
For Btrfs
# <label> Btrfs Label
$ sudo mkfs.btrfs -L <label> /dev/mapper/luks-b20975aa-8318-433d-8508-6c23982c6cde
Then mount the new Btrfs filesystem with compression enabled if desired, where <compression> can take the values zlib|lzo|zstd:
$ sudo mkdir -p /mnt/new_qube_storage
$ sudo mount /dev/mapper/luks-b20975aa-8318-433d-8508-6c23982c6cde /mnt/new_qube_storage -o compress=<compression>
Create a subvolume to hold the data:
$ sudo btrfs subvolume create /mnt/new_qube_storage/qubes
Finally we will tell Qubes to add a new pool on the just created Btrfs subvolume:
$ qvm-pool add poolhd0_qubes file-reflink -o dir_path=/mnt/new_qube_storage/qubes -o revisions_to_keep=2
Note
By default qubes will be created on the main Qubes disk (i.e. a small SSD). To create them on this secondary drive do the following on a dom0 terminal:
$ qvm-create -P poolhd0_qubes --label red unstrusted-hdd
Note
If you want to enable auto-mounting of the new pool, add the relevant line to /etc/fstab , replacing <compression> with your chosen compression algorithm:
/dev/mapper/luks-b20975aa-8318-433d-8508-6c23982c6cde /mnt/new_qube_storage btrfs compress=<compression>,defaults 0 2
